Simple transpose help
lwilt
I've tried tranposing this data a couple times and keep getting errors. Hoping a fresh pair or eyes will be able to do it for me. In the attachment there is a start and finish sheet so you can see how the data currently is and how I'd like it to look. Where every line that the order number is duplicated I want to move the Items(column C) into a single row so each order only shows once.
  • transpose file ex.xlsx
There are better ways of doing this , but here is one way.
Appreciate the help but I have to have it where there are not blank cells before or in between the items. I have to take the items here and put them into a number workbook after this for something else and those blanks would cause problems in step 2.
This should do
Sub test()
    Dim a, i As Long, txt As String, w
    a = Sheets("start").Cells(1).CurrentRegion.Value
        For i = 2 To UBound(a, 1)
            txt = Join(Array(a(i, 1), a(i, 2)), Chr(2))
            If Not .exists(txt) Then
                .Item(txt) = VBA.Array(.Count + 2, 2)
                a(.Count + 1, 1) = a(i, 1): a(.Count + 1, 2) = a(i, 2)
            w = .Item(txt): w(1) = w(1) + 1: .Item(txt) = w
            If UBound(a, 2) < w(1) Then ReDim Preserve a(1 To UBound(a, 1), 1 To w(1))
            a(w(0), w(1)) = a(i, 3)
        i = .Count + 1
    With Sheets("finish").Cells(1).Resize(i, UBound(a, 2))
        .CurrentRegion.ClearContents
        .Value = a: .Columns.AutoFit: .Parent.Select
  • transpose file ex with code.xlsm
