Shortcut key for auto serial number
dingdang
I have downloaded data from other system to excel and have physical invoice which is not serially as per downloaded data, to arrange serially data i am finding invoice no and add serial no to helper column I for sorting assending order in lot of 200.
as data is huge around 20000-25000 i have to remember previous serial no. to input next no, to avoid any duplicate no or skip no. is there any formula vba code which if i assign any shortcut key like "+" and enter auto serial no like 1 ..2..3..200 so on will add in column I
e.g
if 1st invoice no find in cell E25 and serial no in colume I25 input as 1 and next value find in E1100 i will input shortcuy key like "+" in I1100 instead of no 2..3..4
pls help
Hi DingDang,
as i understood you just want to give serial number if there is any value in columnE and itshould not be duplicate & you dont want to skip any number.
please share sample file for the same.
http://chandoo.org/forums/topic/posting-a-sample-workbook
yes, I just want any shortcut key which give auto serial no in colum I instead of inputting manually after finding value in column E.
If you dont have any criteria then you may use below function in cell J2
=IF(E2="","",COUNTA($E$1:E2)-1)
or you may also follow below link of macro enabled file with shortcut command
Ctrl+Shift+T
http://rapidshare.com/files/1718765508/Serial%20Numbers.xlsm
