Shift of data based on Month using VBA
Need a VBA which shifts the data based on month. There are two phases in the file i.e. PHASE I & PHASE II. In dates tab, start date for the project is mentioned (For Phase I & Phase II). In dates tab, For Phase II - Construction start date is beginning in "Dec-18" and in the "Cost" tab data is starting from E10 cell.
If we change the month in the "Dates" tab from "Dec-18" to "Feb-19", all the figures for PHASE II should shift accordingly. So the number 330 should start from cell E12 and go on till E15. Similarly, the figures for column G should also shift and start from G16 instead of G14. For column I, the figures should shift and start from I18. All the figures for PHASE II should shift 2 cells down as per the date mentioned in "Date" tab - cell D8.
So whenever anybody changes the date in Cell D8 in Date Tab, all the figures for PHASE II should shift accordingly.
File is attached.
Thanks in advance :)
What you want done is not possible in the same sheet.
We can have a separate sheet called say RevisedCost , which will correctly reflect the data on the Cost tab , based on the dates entered in the Dates tab.
Is this acceptable ?
See if this is OK. Note that the Phase II start date cannot be earlier than December 2018 , since the formula has not been written to take care of this situation.
