Set reverse order of a several rows in column using formula
Atanu Chanda
Hello Friends,
I have entered data in a propriety software of our company and the first data entered gets stored in it as last row.
Data entry 1: Row 1 : 2315
Data entry 2: Row 1 : 2715
Row 2 : 2315 and so on.
The data entered is random and I cannot sort it in anyway to get it back in its original order when exported to excel from the application.
My data is kind of :
4718
4238
7356
2156
2715
2315
and I want this in inverse order. Is there any formula to do so without the help of VBA.
Any help, much appreciated.
Hi, Atanu Chanda!
Let's suppose you have your data like this:
[pre]
Original Data  Inversed order data  6
4718           2315
4238           2715
7356           2156
2156           7356
2715           4238
2315           4718
[/pre]
Column A, your original data. Column B, the inversed data you want. Cell C1, number or items in A.
Try this:
a) Define a named range TableOriginal from A2:A7
b) type in C1: =CONTAR(TableOriginal) -----> in english: =COUNT(TableOriginal)
c) type in B2: =DESREF(TableOriginal;$C$1-FILA()+1;0;1;1) -----> in english: =OFFSET(TableOriginal,$C$1-ROW()+1,0,1,1)
d) copy down B2 to B3:B7
Regards!
Hi Atanu Chanda, SirJB7 & NARAYANK991,
This formula is also giving similar results:
=OFFSET($C$1,LARGE(--ROW($C$1:$C$6)-1,ROW($A1)),0) [Ctrl+Shift+Enter]
Where... C1:C6 occupy the original list and D1:D6 contains reversed list. ;)
Here's a shorter version, assuming the data is in C1:C6 and formula in D1 copy down
=INDEX($C$1:$C$6,ROWS(C1:$C$6))
