Scraping Website Using VBA - Need Help
Sacbin009
Hi All,
I am trying to get details of top 100 best sellers book from Amazon and all I am able to get is top 20 using below VBA Code:
Sub ImportDatafromAmazon1()
Dim i As Integer
Dim firstRow As Integer
Dim lastRow As Integer
Dim nextRow As Integer
Dim URLstart As String
Dim URLend As String
Dim shStats As Worksheet
Dim shQuery As Worksheet
Dim rgQuery As Range
Dim found As Range
Dim TimeOutWebQuery
Dim TimeOutTime
Dim objIE As Object
URLstart = "https://www.amazon.com/Best-Sellers-Books-Business-Money/zgbs/books/3/ref=zg_bs_nav_b_1_b"
On Error GoTo 0
ActiveSheet.Name = "Amazon B&M - Raw Data"
Set shStats = Sheets("Amazon B&M - Raw Data")
For i = 1 To 5
Sheets("Amazon B&M - Raw Data").Select
Set shQuery = ActiveSheet
Set objIE = CreateObject("InternetExplorer.Application")
With objIE
.Visible = False
.Navigate CStr(URLstart & i & URLend)
TimeOutWebQuery = 10
TimeOutTime = DateAdd("s", TimeOutWebQuery, Now)
Do Until objIE.ReadyState = 4
DoEvents
If Now > TimeOutTime Then
objIE.stop
GoTo ErrorTimeOut
Loop
objIE.ExecWB 17, 2
objIE.ExecWB 12, 2
shQuery.Range("A1").Select
shQuery.PasteSpecial NoHTMLFormatting:=True
objIE.Quit
Set objIE = Nothing
Set found = shQuery.Columns(1).Find("Player", , , xlWhole)
If Not found Is Nothing Then
firstRow = found.Row
If i > 1 Then firstRow = firstRow + 1
GoTo FormatError
Set found = shQuery.Columns(1).Find("Page ", found, , xlPart)
lastRow = found.Row - 1
GoTo FormatError
Set rgQuery = shQuery.Rows(firstRow & ":" & lastRow)
nextRow = shStats.Cells(Rows.Count, "A").End(xlUp).Row
If nextRow > 1 Then nextRow = nextRow + 1
rgQuery.Copy shStats.Cells(nextRow, 1)
shQuery.Delete
shStats.Columns.AutoFit
MsgBox "Query complete"
Exit Sub
FormatError:
ImportDatafromAmazon2
Exit Sub
ErrorTimeOut:
objIE.Quit
Set objIE = Nothing
MsgBox "WebSite Error"
I have also tried to use RSS feed but results are similar. I would highly appreciate if you can please advice me how can I import this data in excel using VBA.
Best Regards,
Sachin
(EDITED, code tags)
@Sacbin009
Your posted code seems to be missing another routine (ImportDatafromAmazon2).
FormatError:
Also since you have Exit Sub without If statement or other condition... once code runs to that point, it will exit the routine.
I'd suggest you upload sample workbook to demonstrate your desired result (few data manually entered).
