Running Total of 12 previous months excluding current month
Shay A
I am trying to build a DAX expression to help me check, for each of the following months- 10/2017 through 09/2018 if there was sales ofat least one USD in the previos 12 months. For example, for 10/2017, the expression checks month 10/2016 till 09/2017. Also, the the formula shold check if there are sales on the month evaluated (10/2017 in this example).
TY!
As always, it would help us in helping you, if you upload sample workbook with data and manually created desired result.
First of all, do you have a calendar table in your data model, and does it contain a column with MonthRef like mm/yyyy-format that allows you to link the sales data with the calendar?
If so you can more easily use a real date filter on you sales table in the required measurement.
Hmm, without sample hard to give you exact answer.
Depending on what date ranges are present in your data set, calculation changes a bit.
When you have date dimension table (DimDate), you could use following construct.
RSUM12M := CALCULATE (
    [Value],
    DATESBETWEEN (
        DimDate[Date],
        SAMEPERIODLASTYEAR ( NEXTDAY ( LASTDATE ( DimDate[Date] ) ) ),
Full explanation of construct can be found in link below.
https://www.sqlbi.com/articles/rolling-12-months-average-in-dax/
