Retrieving values from a worksheet using userform
It's me again asking for your help.
I created a userform (userform7) to view the existing values of a worksheet (Logs).
The last value of combobox (combobox12) prompts as a default value. The default value (combobox12) should be able to retrieve the required data from worksheet (Logs) whenever I click the View button - I tried to use the WorksheetFunction.VLookup but I guess there is something wrong with my code.
I badly need your expertise on this please. I also attached the file that I am using for your reference.
Instead of using vlookup, we can find the row number of the given value by using find method and accordingly populate the values...
Here is the updated file..
