Required formula for Minus Percentage
Khalid NGO
Hello Everyone,
Greetings from Pakistan...
I am trying to get qty with Minus percentage but not getting the required.
Column 'B' = Actual Quantities
Column 'C' = 15% of Actual Qty.
Column 'D' having Total Qty. (actual + 15%)
Required Column 'G'
a formula that will calculate Total - 15% Bonus
I tried =D4-(D4*$C$3/100) Result = 4,888 which is not required (required result = 5,000)
Sample file also attached.
Thanking you in anticipation.
BR,
Khalid
Hi Khalid,
Simply calculate D4 / (1 + 15%). It would be a good idea to store your bonus percentage as a real % number (0.15) and percentage formatting to display it is a percentage. Pls enter 0.15 in the cell C3 and press Ctrl + Shift + 5
Anand
Hi Khalid,
Anand
Wow thats great...
Thanks Anand for your valued suggestion.
Hi Khalid,
You can also calculate the figure 5000 directly from Bonus amount by : Bonus Amount / 0.15
...Since A and B cols will not be present.
Hi Khalid,
Thanks Sir Faseeh,
Very nice solution, but actually i don't want to use Actual and Bonus Columns, therefore i think =D4/(1+15%) is good for me.
Appreciate your reply.
