Removing duplicates and ignoring more than 1 row of headers
CLoos
Hi -
I am creating a macro to manipulate a large report. And at the end of my macro I want to remove duplicates excluding my header rows, There are four header rows. Finding possible solutions on forums, everything I am trying isn't working properly.
This is removing more than just duplicates in my data
With ActiveSheet.UsedRange
.Resize(.Rows.Count - 4).Offset(4, 0).RemoveDuplicates Columns:=8
And this is removing a row out of my headers
Dim FirstCell As Range, LastCell As Range
Set LastCell = Cells(Cells.Find(What:="*", SearchOrder:=xlRows, _
SearchDirection:=xlPrevious, LookIn:=xlValues).Row, _
Cells.Find(What:="*", SearchOrder:=xlByColumns, _
SearchDirection:=xlPrevious, LookIn:=xlValues).Column)
Set FirstCell = Cells(Cells.Find(What:="*", After:=LastCell, SearchOrder:=xlRows, _
SearchDirection:=xlNext, LookIn:=xlValues).Row, _
Cells.Find(What:="*", After:=LastCell, SearchOrder:=xlByColumns, _
SearchDirection:=xlNext, LookIn:=xlValues).Column)
Range(FirstCell, LastCell).Select
.Resize(.Rows.Count - 1).Offset(4).Select
Range(FirstCell, LastCell).RemoveDuplicates Columns:=8
You realise that with Columns:=8 at the end of that code line, it is looking only at column 8 (column H, perhaps, if your data starts in column A) of that range to find duplicates? If you want to include more columns in that search for duplicates then you need to add them, eg.:
Columns:=Array(1, 2, 8)
The last line of code is the one which is removing duplicates :
where the highlighted range is the one which will be used to remove duplicates from.
Before this line of code , you are doing a selection of a range which excludes the header rows , in this line :
To actually make use of this , can you not have the following as the last line :
Selection.RemoveDuplicates Columns:=8
Thank you, I hadn't thought of this but it might work with looking at other columns.
Oh!!! I did not realize it was not "holding" the selection from my resize/offset statement. This makes sense. Thank you.
