Remove duplicate per column in a multi columns range
arishy
For each multi row column in a range I want to loop each column and remove duplicate, At the same time compress the column by removing the duplicate.
Each Column has:
HEADER1
Value1
Value2
Value2
Value3
Value1
The cleanup column:
HEADER1
Value1
Value2
Value3
The Clean up column replaces the original data.
Then loop the next column
Hi arishy,
What version of Excel do you use, if it is 2007 or higher then there's option named remove duplicates which will do it for you.
Test this code on a backup. Please adjust the range A1:F7 to suit.
[pre]
Public Sub RemDupes()
Dim c As Range
For Each c In Range("A1:F7").Columns
c.RemoveDuplicates 1, xlYes
Next c
[/pre]
