#Ref! error while using OFFSET FUNCTION
Hi Team
Whenever I am using Offset function, it works, yet when I delete the base cell(Entire row or column), the first value in offset function , I always get ref error in range or any other way using via offset. Is there any solution to this problem?
RatanB
Try using INDIRECT function for Reference part of OFFSET function..
something like this
OFFSET(INDIRECT("$A$1").....
See the attached..and delete Column A in the attached
But when I am using the formula in the following way
it is again giving error
=OFFSET(INDIRECT("$A$1"),1,1,0,0)
I have to use the formula in creating a dynamic range, where every week base cell or row or column is deleted and we get ref error.
Please check.
RatanB
Remove "0,0" portion and see if it works. Or at least replace it with "1,1"
You are basically telling the function to return value of no cell by "0,0".
