project management Dashboard
Peter Garwood
Hi I recently purchased the excel based project management dashboard, I'm in the UK and therefore I would like to change the currency from $ to £... could you please tell me how to do this.
What Excel Version are you using?
In general Select cell where you want to change symbol, Press Ctrl+1, Accounting will be selected, Change Symbol.
Hi Peter!
Thanks for purchasing chandoo's one of the best product..
Believe me, you can customize it as much as required.
If @Somendra Misra 's suggestion, not worked for you then..
Please contact chandoo.d[at]gmail[dot]com @r1c1 he will change the dashboard as per your requirement and system setting.
Hi, Peter Garwood!
As a new user you might want to (I'd say should and must) read this:
http://chandoo.org/forum/forums/new-users-please-start-here.14/
And regarding your issue, maybe you'll find interesting these 2 links as related to the same product:
http://chandoo.org/forum/threads/issues-on-project-portfolio-dashboard.14520/
http://chandoo.org/forum/threads/additional-issues-found-in-pp-dashboard-vba-v1.15237/
If I were you I'd watch these threads regularly since there should be posted the fixes for the describes problems.
Regards!
