B baixuefen New Member Aug 22, 2012 #1 Is there any possibilities to create a process flow chart using Excel?
Faseeh Excel Ninja Aug 22, 2012 #2 Hi baixuefen, Welcome to the Forums!!! You can use Drawing Objects to create a flow Chart. But if you are going to do really technical stuff like drawing and dimensionless, assembly drawings or floor plans and others, i would suggest you to use MS Visio. Regards, Faseeh
kuldeepjainesl Member Aug 22, 2012 #3 Hi Baixuefen, Just last week I used excel for such a task. Sample low resolution image is available at http://sdrv.ms/Sn6BCr if some like this is your expectation, Excel is perfect. Regards,
bobhc Excel Ninja Aug 22, 2012 #4 Good day baixuefen You would probably find what you want here http://creately.com/diagram-type/templates/flowcharts
N ninad7 Member Aug 22, 2012 #5 @OP: Use the drawing objects. But XL is not best suited for flow charts. You may be better off with Visio. Depends on your purpose.
