Problem with DateLastModified
Hello forum,
I want to manipulate image files by transferring them to another folder and changing the name. See the code used.
The problem is that on the instruction "ModifiedDate_MyFile MyFile.DateLastModified =" VBA responds with a message "Invalid Procedure".
Could a member of the forum help me to solve this problem.
Thank you in advance for your answers.
Harry
Sub ChangeFileName()
    Dim MyFile As String, OldPath As String, NewPath As String
    Dim OldName As String, NewName As String
    Dim ModifiedDate_MyFile As Date
    OldPath = "C:\Users\XX\Documents\YY 2015\"
    NewPath = "C:\Users\XX\Documents\YY\2015_03_02\"
    MyFile = Dir(OldPath & "DSC*.jpg")
        Do While Len(MyFile) > 0
        OldName = OldPath & MyFile
        ModifiedDate_MyFile = MyFile.DateLastModified
        NewName = NewPath & " 20150302 " & MyFile
        Name OldName As NewName
    Loop
First check this!
ModifiedDate_MyFile = (OldPath & MyFile).DateLastModified
2nd
The DateLastModified is a part of Scripting.FileSystemObject so you need to reference it or do late binding for the same.
Dim fso As Object
Set fso = CreateObject("Scripting.FileSystemObject")
ModifiedDate_MyFile = fso.GetFile(OldPath & MyFile).DateLastModified
3rd method is like as below without any ref.
ModifiedDate_MyFile = FileDateTime(OldPath & MyFile)
Some ref to you..
https://msdn.microsoft.com/en-us/library/office/gg251660.aspx
http://stackoverflow.com/questions/...st-modified-date-explorer-value-not-cmd-value
Hi Harry ,
Try this :
Sub MoveFiles()
'  Include a reference to :
'  Microsoft Scripting Runtime
    Dim FSO As Scripting.FileSystemObject
    Dim SourceFolder As Scripting.Folder
    Dim SourcePath As String, DestPath As String
    Dim strFile As String
'  //Change the path to the source folder, accordingly
    SourcePath = "C:\Users\XX\Documents\YY 2015\"
'  //Change the path to the destination folder, accordingly
    DestPath = "C:\Users\XX\Documents\YY\2015_03_02\"
    If Right(SourcePath, 1) <> "\" Then SourcePath = SourcePath & "\"
    If Right(DestPath, 1) <> "\" Then DestPath = DestPath & "\"
    Set FSO = New Scripting.FileSystemObject
    Set SourceFolder = FSO.GetFolder(SourcePath)
    strFile = Dir(SourcePath & "DSC*.jpg")
    Do While Len(strFile) > 0
      ModifiedDate_MyFile = SourceFolder.Files(strFile).DateLastModified
      OldName = SourcePath & strFile
      NewName = DestPath & " 20150302 " & strFile
      Name SourcePath & strFile As DestPath & strFile
      strFile = Dir
    Loop
Hello the forum,
Hi Deepak Narayan,
First of all, my apologies for this late reply.
Thank you to both of you for your response.
@Deepak
The first solution generates a compiler error
The second solution is good but more explicit in the Narayan’s code
The third solution works properly.
@Narayan
Thank’s for this ready-made solution. It’s exactly what I need.
Have a good day.
GiHem
