Problem in applying IF formula for 25 conditions
Status
Not open for further replies.
Please use Sumifs function instead of 25 If function as per following set up.
In Result G3, enter formula:
=SUMIFS(C:C,A:A,E3,B:B,F3)
82640
Dear Sir,
Thank you for your response.
But My query is " If A3=1 & B3=1 then the result should be 1.
Likewise in all the 25 conditions (C3=1,C4=3,C5=6) etc.
Can you please help me with the formula ?
Example formula i applied - =(IF(AND(U5>=1,V5<=1),"1",IF(AND(U5>=1,V5<=2),"3", IF(AND(U5>=1,V5<=3),"6", IF(AND(U5>=1,V5<=4),"10",IF(AND(U5>=1,V5<=5),"15", (After this its not calculating) IF(AND(U5>=2,V5<1),"2".
Attached Excel sheet for your reference.
Pradeep Moharana
Dear Sir,
Pradeep Moharana
Please google: "How to use SUMIFS functions?" before you ask any question.
Your post#1 question is solved. And "new thread for new question"
This thread is closed.
Status
