Problem Hiding Columns...
aklewe
Why it is the seemingly simple tasks can give us the most trouble? I want to run a simple bit of code to hide columns E:M like so...
Columns("E:M").Select
Range("E3").Activate
Selection.EntireColumn.Hidden = True
HOWEVER, when I run the above macro, it hides all columns A:M... does anyone have a clue why this may be happening? The above is the only code in the macro currently.
Thanks!
aklewe
*happy excel geek*
Good day aklewe
If you record a macro while doing as you want it records as per your code but without the Range(“E3”).Activate
Sub Macro1()
Thanks for the help. If I remove 'Range("E3").Activate', I still get the same result when I run the macro...it hides columns A:D as well as E:M. I really am puzzled.
aklewe
*happy excel geek*
Narayan - you are genius! I knew it had to be something on my spreadsheet itself causing the problem. I unmerged the cells I had across those columns, and now the code works just fine.
THANKS ALL!
aklewe
*happy excel geek*
