Power Query: % of total
Lance Pretorius
In Power Query how do you add a custom column that displays row total as % of column total?
See Below
Thanks in advance
IndexNameTotalColumn to be addedColumn to be added formula
1A100
4.76%​
=$D4/SUM($D$4:$D$9)
2B200
9.52%​
3A300
14.29%​
4B400
19.05%​
5A500
23.81%​
6B600
28.57%​
If your table would be in Excel
let
    #"Changed Type" = Table.TransformColumnTypes(Source,{{"Index", Int64.Type}, {"Name", type text}, {"Total", Int64.Type}}),
    #"Added Custom" = Table.AddColumn(#"Changed Type", "Custom", each List.Sum(Table.Column(#"Changed Type","Total"))),
    #"Inserted Percent Of" = Table.AddColumn(#"Added Custom", "Percent Of", each [Total] / [Custom] * 100, type number)
in
Note the step Percent Of is doable via the ribbon:
Select column total then column custom then apply as in screenshot
59946
  • PercentOfGrandTotalSample.xlsx
This sort of calculation is best done in DAX. It's more efficient.
However, there are many ways to do this. Using GUI as GraH showed above for one.
Using calculated column like below.
=[Total]/List.Sum(Source[Total])
