Power queries issue
jiajia97
Hi team,
May I ask what is the problem with my power queries are not available to update when I update my data in tables? Even I have save it and refresh the data. Is it will be affected after I add the VBA Macro Button?
May I know why my append queries not available to update when I fill in data in table and refresh the data?
Attach a sample workbook
Attach a sample workbook (not a picture or pasted copy). Make sure there is just enough data to demonstrate your need. Include a BEFORE sheet and an AFTER sheet in the workbook if needed to show the process you're trying to complete or automate. Make sure your desired results are shown, mock them up manually if necessary.
Remember to desensitize the data.
Than you for your reply. I had solved the problem. However, I had another question on why the icon will missing when we get data fro power query?
