Lauren Thomas
Hello
I am new here and in desperate need of some help!
I am wanting to create a formula that says If J7 say "ACTUAL" then do this formula but if it says "FORECAST" then do this formula using Vlookups. I also want to remove the N/A and to generate 0 if nothing is returned.
I think that I should be able to do this using the IF AND function but putting it together is proving difficult.
I think it should be something like this but it needs some tweaking:
If cell J7 says Actual I want it to do the red formula, if it say forecast I want it to do the blue formula. Am I making sense?
=IF((AND(J$7="ACTUAL",J$7="FORECAST")),(ISNA(VLOOKUP($A25&$D$4&J$6&J$7,'FIN TB'!$A$5:$K$29981,8,FALSE)),0,VLOOKUP($A25&$D$4&J$6&J$7,'FIN TB'!$A$5:$K$29981,8,FALSE)),IF(ISNA(VLOOKUP($A41,'FIN BUDGET & FORECASTING'!$A$7:$T$111,6,FALSE)),0,)+VLOOKUP($A41,'FIN BUDGET & FORECASTING'!$A$7:$T$111,6,FALSE)
Best wishes
Lauren
Best wishes
Lauren
