Please Guide For my Code to run a micro for auto numbring
Hello Everybody,
I have write a little code for auto numbering in my sheet.The Sheet name is sheet 1 and the column are selected for the code is A and B.
Sub mylastcell()
      Cells(Rows.Count, 1).End(xlUp).Select
For i = 0 To 5
ActiveCell(i, 1).Offset(2, 0) = i + 1
I required some help to modify my code in such a way that when i enter data in column B starting from row 3,the serial no should appear automatically in column A as per entry of column B.
I used the For loops i=0 to 5 but want it for unlimited rows.Please let me help .
  • autoNum.xlsm
Paste the following code in the Sheet Level Module :
Dim lastRow As Long
    lastRow = Range("B" & Rows.Count).End(xlUp).Row
    Range("A3").AutoFill Destination:=Range("A3:A" & lastRow), Type:=xlFillSeries
Also, you must enter the first serial number in A3 for the above macro to
work for all other entries.
Hi !
So you must paste next code in the worksheet module only :​
    If Target.Column = 2 And Target.Row > 2 Then Target(1, 0).Value = Target.Row - 2
Dim lastRow As Long
Thanks for your reply but the code gives me error.
Hi !
Yes... its ok now.Thanks for your nice support
