Percentage difference between numbers
luvfahad
I understand that the formula to calculate an percentage increase between numbers is,
=(A1-B1)/B1
But when does one use =(A1-B1)/A1, is that the formula to show percentage decrease?
No, it would be the same formula
=(A1-B1)/B1
Where A1 is new value, B1 is old value.
Example
Start with 100 units, end with 110 units. This is an increase of:
=(110-100)/100
=10/100
10%
If we start with 100 unites and end with 90, this is a decrease of:
=(90-100)/100
=(-10)/100
-10%
The sign of the number indicates whether it's an increase/decrease.
Well, that all depends on which of the cells above are the original and new amounts. If we let A1 -> Original Amount and B1-> New Amount then the percentage increase and decrease formulas are as follows:
Percent Increase:
(B1-A1)/A1
and Percent Decrease:
(A1-B1)/A1
Both formulas always have this generalized form:
(POSITIVE DIFFERENCE) / (ORIGINAL AMOUNT)
Remember, the subtraction arithmetic in the numerator should always be positive - if it's not, then you are using the wrong measure. The denominator is always the original amount.
This might be helpful for you, too:
http://www.buzzle.com/articles/calculate-percent-difference.html
