offset to reach extreme left cell in column A
Mr.Karr
Hello
Can anyone please provide a code snippet so to move the cursor or select the extreme cell in left side of column A.
In detail: Say.. I need to paste certain free text parallel to the cell user selects, I have data from column A to AZ. I tried using offset function but it's not giving accurate results or probably I'm trying it better.
Can anyone help to get this done?
Thanks in advance
Assuming you want the cell in column A that is on the same row as the activecell, this should work:
Cells(ActiveCell.Row, 1).Select
