Sheet 2 has data= ID#, first name, last name, child name, amount by each month. All in each individual column.
Sheet 1 has to pull the information. So if ID # is entered in a specific column in sheet 1, The info like First name, last name and each month amount should be able to pull in a separate column of sheet 1. I can use Vlookup, but I would like to use offset and match fromula. I have figured out how to use Offset formula, but I cannot put match formula on offset formula to pull the information by ID # in sheet 1. I need to know specifically match formula what to enter in lookup_value, lookup_array and which column should be linked in sheet one or sheet two.
Can anyone help me please?
Thank-you in advance for your time and help
