numbering for top 3 highest and lowest value with comment
Ajinkya
Dear Frineds,
I were been trying to mark a numbering for top 3 highest and lowest value with loss and gain comment.
Coloumn B having following data
B2= -78%
B3= -75%
B4= -61%
B5= -58%
B6= 43%
B7= 44%
B8= 47%
B9= -16%
Comments are in coloumn C (want a formula)
C2= 1 Loss
C3= 2 Loss
C4= 3 Loss
C6= 3 Gain
C7= 2 Gain
C8= 1 Gain
thanks friends, missing you....
Hi Ajinkya,
For Largest Value & Comment Respectively First & Second:
[pre]
=INDEX($B$2:$B$9,MATCH(LARGE($B$2:$B$9+ROW($B$2:$B$9)/1000000000,ROW(B1)),$B$2:$B$9+ROW($B$2:$B$9)/1000000000,0),0)
=INDEX($C$2:$C$9,MATCH(LARGE($B$2:$B$9+ROW($B$2:$B$9)/1000000000,ROW(B1)),$B$2:$B$9+ROW($B$2:$B$9)/1000000000,0),0)
For Lowest Value & Comments Respectively:
=INDEX($B$2:$B$9,MATCH(SMALL($B$2:$B$9+ROW($B$2:$B$9)/1000000000,ROW(F1)),$B$2:$B$9+ROW($B$2:$B$9)/1000000000,0),0)
=INDEX($C$2:$C$9,MATCH(SMALL($B$2:$B$9+ROW($B$2:$B$9)/1000000000,ROW(F1)),$B$2:$B$9+ROW($B$2:$B$9)/1000000000,0),0)
[/pre]
press Ctrl+Shift+Enter & Drag down.
Faseeh
[ This Marks my 1K posts :) ]
Hi Faseeh,
Congratulations for 1K milestones.
thnaks for ur formula, but it is slightly matching with my requirement, because im looking for "Gain/Loss comment and numbering, should come automatic with formula or something..."
like,
1 Loss
2 Loss
3 Loss
3 Gain
2 Gain
1 Gain
Thanks U Ajinkya, Try:
=IF(B2=SMALL(DATA,1),"1ST LOSS",IF(B2=SMALL(DATA,2),"2ND LOSS",IF(B2=SMALL(DATA,3),"3RD LOSS",IF(B2=LARGE(DATA,1),"1ST GAIN",IF(B2=LARGE(DATA,2),"2ND GAIN",IF(B2=LARGE(DATA,3),"3RD GAIN",""))))))
Where Data = $B$2:$B$9
Or See this file:
http://dl.dropbox.com/u/60644346/Ajinkya%20Smallest%20%26%20Largest.xlsx
In the interest of choice, here is one more approach:
=IFERROR(IFERROR(MATCH(TRUE,B2=SMALL(PData,{1,2,3}), 0) & " Loss", MATCH(TRUE,B2=LARGE(PData,{1,2,3}), 0) & " Gain"),"---")
Copy down to additional rows as needed.
Cheers,
Sajan.
Hi Ajinkya,
The formula uses a Name called "PData", which refers to B2:B9 in your original post. (If you prefer, you can replace references to PData with the actual range.)
Using your sample data, I got the following result:
[pre]
1	ColB	ColC
2	-78%	1 Loss
3	-75%	2 Loss
4	-61%	3 Loss
5	-58%	---
6	43%	3 Gain
7	44%	2 Gain
8	47%	1 Gain
9	-16%	---
[/pre]
The formula needs to be put into cell C2, and copied down:
Hope this helps.
Cheers,
Sajan.
Hi Ajinkya,
This is my first post, i hope you will like below solution, if there is any error please suggest:
=IF(IF(B2>0,RANK(B2,$B$2:$B$9),RANK(B2,$B$2:$B$9,1))>3,"",IF(B2>0,RANK(B2,$B$2:$B$9)&" Gain",RANK(B2,$B$2:$B$9,1)&" Loss"))
Use above formula in cell c2 and drag down.
