Number formatting by default
Greetings!!
I have to manually adjust the number formatting i.e. 12345 to 12,345(without decimal)
Is there any way to get this feature by default on new and old files
Neeraj Kumar Agarwal
Here's one way to do it.
1. As vletm suggested, go to "Style" ribbon tool and right click on "Normal" and modify (or add another rule). And set it to number format of your choice.
2. Then save the blank file as template. Any new workbook created with this template will inherit style setting.
3. If you want to make it default template, save the template in XLSTART folder.
Here's one more idea. You can implement a code like below which will apply formatting to a cell automatically if cell has no format set to it. It goes in thisworkbook module.
Private Sub Workbook_SheetChange(ByVal Sh As Object, ByVal Target As Range)
Dim rg As Range
For Each rg In Target
    If rg.NumberFormat = "General" Then
        rg.NumberFormat = "#,##0"
