Need your help for 3 major problem
For the 1st issue use 'Cell value is' instead of 'Formula is' in conditional formatting
Will comback on the remaining issues
Use the below procedure for the 2nd requirement
Sub Formatting()
  Range("A1").Select
  On Error GoTo Err
  Do Until ActiveCell.Column = 20000
  Columns(ActiveCell.Column).Interior.ColorIndex = 6
  Columns(ActiveCell.Offset(0, 1).Column).Interior.ColorIndex = 3
  Columns(ActiveCell.Offset(0, 2).Column).Interior.ColorIndex = 44
  Columns(ActiveCell.Offset(0, 3).Column).Interior.ColorIndex = 1
  ActiveCell.Offset(0, 5).Select
  Loop
Err:
Different document is having different start and end date , and these range can be change as per the project priority.
The challenge in your 3rd task is how to arrive at start date and end date for a project based on coloring
We will not be able to create conditional formating based on color of cells
Let me explore other methods and come back
I have a logic but dont know how to transform it into code.
logic is " we cross check IS CELL COLOR = YELLOW, AND IS DATE IS TODAY
IF YES THEN CELL COLOR ( RELATED LEFT SIDE DOCUMENT LIST CELL) = GREEN
THIRD FLAG IF DATE IS LESS THAN TODAY THEN CELL COLOR = RED
