Need you Help with filter function
geo Jul
Dear Expertise
please need your help
I need to filter column B according to I3:J5 and all three conditions for each name must be Met
example
if the name Sam had been filtered the three requirements should have
1: Incentive Level is equal to 3
2: Product Knowledge is equal to 4
3: Personal Skills is equal to 5
I really appreciate any help you can provide.
I am using Excel 2016 and 365 version
  • Test 15.11.2024.xlsx
Here is a 365 solution:
=LET(t,TEXTJOIN(" ",,J3:J5&I3:I5),c,C3:C32,de,D3:D32&E3:E32,
f,FILTER(c,ISNUMBER(FIND(de,t))),
SORT(UNIQUE(FILTER(f,BYROW(f,LAMBDA(r,SUMPRODUCT((f=r)*1)=3))))))
  • geo Jul Test 15.11.2024 SPILL 365 AliGW.xlsx
Thank you so much; I appreciate your help with this problem​
if you please is it possible to replace the LAMBDA function with another as some co-workers are not familiar with this function​
No, sorry - if you specifically did not want the LAMBDA function to be used, you should have said so at the start.
I don't see why it should be an issue when ONLY the ranges in the first line will ever need changing:
Take it or leave it.
