OK lets not let the fact that there is no sheet 24 or 25 so using the cell references will be difficult. Firstly I don't like the use of indirect formula. I think you can set your workbook up in such a way as to have a consolidation sheet and 'tap' this sheet for the information you require. Then you would flick from a vlookup to a sumifs formula. You do not have a big file as it currently stands and this would allow you to change your setup slightly by storing all the individual sheets in one Consolidation sheet which using a column to differentiate each block of data.
OK here goes. Put this formula in cell B9 of the Price volume tab
=VLOOKUP($A9,INDIRECT("'"&B$8&"'!B2:R302"),16,0)
Drag it across and down when you get to Col J and L you might want to change the header to read 244 and 245 respectively.
