need to skip 11-30 lines code using macro
suneetha
I have three sheets where Data is sheet is given input
SQL Template -SQL Queries given to be generated values are passed from the Data Sheet %A%,%B% etc
SQL- sheet where queries generated dynamically on click of generate SQL button
For Ex if column A any empty value is passed, SQL queries generated from 11to 30 from the SQL template.
I need avoid lines 11to 30 which are in template when empty value %A% is passed.
Please suggest and find the attached Sheet
Suneetha
  • Copy of Notification_Config_Script_Generator_Batch_Event_all_bck (1) (1).xls
