Need Some Help
Pushppreet
I need some help with the attached file. My friend had created this file for me initially and now I want some changes to be done and I am stuck as he is on leave.
In the attached file, Worksheet 1 (Trng & Trainer Search) is working fine where when I put the training name or the trainer name the schedule reflects respectively. However in worksheet 2 (Monthly Search) I want that when I select the month, the complete data from sheet 3 (Calendar) of that month should get reflected in sheet 2 (Monthly Search).
Can someone please help me with this.
Thank you in advance.
Pushppreet
  • 14 Dec (2) CS Training Plan - 2017 New PS.xlsx
Welcome to the forum :)
Here you go... should work as intended.
I need some urgent help with the attached file. My friend had created this file for me initially and now I want some changes to be done and I am stuck as he is on leave.
Can someone please help me with this as its very urgent and important for me.
Pushppreet
PFA. Let me know if you have any clarification.
  • 14 Dec (2) CS Training Plan - 2017 New PS_OVER.xlsx
Don't mention it... glad I could help ;)
Hey,
I have a question, In the first worksheet, would it be possible to have 2 trainer / training search options... As in I select one trainers name and get a display and then I would like to have another row where I can search for another trainers / training under it without affecting the result of the first column..?
Have attached the file for your reference.
Thanks in advance.
Pushppreet
  • 2017 CS Training Plan - WO Lgo.xlsx
