ThrottleWorks
Hi
I need help for selecting particular range by VBA.
I have a macro which select last cell in a particular column.
I want to select a range from that particular cell.
How can do it using Offset in VBA.
Following example will be easier to understand.
My last cell is “B18”, this is identified by the macro.
Now I want to select Range (“B18:AH18”) with the help of macro.
The cell reference B18 is not fixed, this can be B25, B50 etc.
I want my macro to select a range from that particular cell.
If the last cell is B50, then the macro should select Range (“B50:AH50”).
Please help…
Please help…
