Need offset in Match / index function
andreas.wpv
I use index(match) functions to compare two lists.
Now I want to use not always the same range for my this, but a shifting range:
cell G1: match("andreas", B1:F10) = 4
now I want
cell G2: match("Willi", B1+4:F10) =...
So the second range is based on the first match.... with only one of the coordinates changing.
Possible? If any without VBA?
Hi and Welcome Andreas,
Try this:
=MATCH('andreas',INDIRECT(CONCATENATE("B",ROW(OFFSET(B1,2,)),":F10")),0)
You can change the "2" Value in the offset to the increment you want, or point it to a value in a range.
Thank you Nacky!
I had to change it a bit, the row / offset did not work. so I ended up just with
IF(L2>=2,SUM(N2,MATCH(J2,INDIRECT(CONCATENATE("$A",(N2+2),":$A$24")),0)),0)
where N2 is based on the first match (looking for 2nd match to then index)
Never encountered indirect before, very helpful.
