need help
Ladystark
I have an excel sheet and I need some help in writing formula.
The excel has Sheet 1 with old data, Sheet 2 with new data and contains some old data that can be found from Sheet 1.
What I want to happen, is it will remove all duplicates found in Sheet 1 and Sheet 2 and the results will be shown in Sheet 3.
I hope someone can help me writing the formula for this..Thanks in advance
  • CODE.xlsx
hii @Ladystark ,
Please find the attaced solution using Power Quey.
Sheet 1 Data
1.Convert Your data into Table (Short key is Ctrl+T)
2.Go to Power Query Tab
3. Select Close and Load only Connection.
Sheet 2 Data
Then Go to Append Option
1.Primary table Select Table 1
2.Table to Append to primary table select table 2
3. power Query Window will open.
4.Go to Home tab in power Query >>Keep rows >>Select keep Duplicate option
5. Go to Home tab in power Query >>Remove Rows >>Remove Duplicate
6.Click on Close and load (1 st option )
Regard
Rahul shewale.
  • Screen clipping taken 11-09-2017 (as PDF).pdf
  • CODE.xlsm
