Need Help with Vlookup Formula
gmfston
Hello Ninjas,
I am looking for a formula that will populate the values from column C (sheet 2) to column C (sheet 1) if it finds matching data in both columns A & B in sheet 1 and sheet 2. If it does not find matching values in columns A & B, then populate column C, if columns B match in sheets 1 and 2.
Thank you in advance for your assistance.
Best regards,
Gina
  • chandoo position category.xlsx
perhaps:
helper column in sheet 2 in E, concatenating columns A & B and then
=IFERROR(INDEX(Sheet2!$C$2:$C$61,MATCH(A2&"-"&B2,Sheet2!$E$2:$E$61,0)),VLOOKUP(B2,Sheet2!$B$2:$C$61,2,FALSE))
  • Copy of chandoo position category.xlsx
Hi Try this in Sheet1 C2 (Ctrl+shift+enter)
=INDEX(Sheet2!$C$2:$C$61,MATCH(1,(Sheet2!$A$2:$A$34=Sheet1!A2)*(Sheet2!$B$2:$B$34=Sheet1!B2),0))
  • chandoo position category1.xlsx
perhaps:
Thank you G. Unfortunately, I cannot concatenate the columns on my spreadsheet or it will corrupt all my other formulas on the spreadsheet that were not displayed but I do appreciate your assistance.
Thank you,
Gina
Gina, you can replace the helper column with a virtual range in the name manager.
rKey = Sheet2!$A$2:$A$61&"-"&Sheet2!$B$2:$B$61
Formula on Sheet 1 in C1: =Sheet2!$C$2:$C$61,MATCH(A2&"-"&B2;rKey,0))
But 1 question for row 7, what is the expected result?
This one returns ADM (since there is only a dpt value), whereas the previous one returned PHD, the first lookup value.
  • Copy of Copy of chandoo position category.xlsx
