Need help with vba
sms2luv
Hi all,
A very very kind and nice person made a file for me.
He altered it several times as per my requirement.
However I have some issues and would request someone to do the below.
Comment the code for explanation, to know how of works.
If you check the file, Short break, lunch, meetings numbers are not matching as per the pivot table created in another sheet(raw data is in Login sheet, and has date wise data for breaks and other Modes). If I sum up short break for any particular day, the same is not displayed correctly in the output sheet
Request you to view the file
  • Raw(1).xlsb
I get an error when I try opening your file after I have downloaded it.
Can you check at your end by downloading it from here and opening it ?
