I am looking to populate the salaries & fte data by department from the sheet 2 to 1. I am not sure if I should be using a modified index and match formula. Thank you in advance for your help.
Initially the formula didn't work but I realized it was because I needed to remove the absolute formula from sheet1!D1. Now it works. Thank you so much! I really appreciate your prompt reply.
