Need help with formula
mithil1
In column A I have text like mentioned below. I am trying to separate the City Name and date in two separate columns. I don't need the other text.
Alameda 1-10-20 CSV-PAY SUMMARY RUN.csv
Palm Harbor 1-15-20 Hourly CSV-PAY SUMMARY RUN.csv
Palm Harbor 1-15-20 Salary CSV-PAY SUMMARY RUN.csv
Basically, there are various combinations like above and there are different city names. I tried using mid, search, left, right, but its not helping.
Will appreciate help.
~M
Using Power Query I split the columns Non-Digit to Digit
Split again Digit to Non Digit
Merged the numerical data
Deleted the non-essential columns
Here is the Mcode for those steps
let
    #"Split Column by Character Transition" = Table.SplitColumn(Source, "Column1", Splitter.SplitTextByCharacterTransition((c) => not List.Contains({"0".."9"}, c), {"0".."9"}), {"Column1.1", "Column1.2", "Column1.3", "Column1.4"}),
    #"Split Column by Character Transition1" = Table.SplitColumn(#"Split Column by Character Transition", "Column1.4", Splitter.SplitTextByCharacterTransition({"0".."9"}, (c) => not List.Contains({"0".."9"}, c)), {"Column1.4.1", "Column1.4.2"}),
    #"Merged Columns" = Table.CombineColumns(#"Split Column by Character Transition1",{"Column1.2", "Column1.3", "Column1.4.1"},Combiner.CombineTextByDelimiter("", QuoteStyle.None),"Date"),
    #"Removed Columns" = Table.RemoveColumns(#"Merged Columns",{"Column1.4.2"})
in
    #"Removed Columns"
Thanks Alan! I have not used power query formulas before. Is there a way we can just use formula in excel? I will try though.
I really thank you for taking time out and responding.
Mi
Not in my skill bank. If you are interested in learning about PQ, then click on the link in my signature.
