CaptRDMretired
I am in the process of creating a workbook for my wife's use at work and, as yet, do not have a viable sample file to include - I will attempt to explain. Here are the two pertinent areas of concern, Table1 and Table2.
Table1: Date Code Cases Net Lbs
If the data in Table2 is altered to reflect the new Lbs/Case for Widgets then all entries in Table1 change to reflect the new data. This, in turn, changes all the Weekly, Monthly, Quarterly and Yearly dashboard type worksheets that pull data from Table1.
So-----Is there a way to change/add updated data into Table2 that would only affect the calculations in Table1 and subsequent areas of the workbook such that, in the example, when the Code and Cases were entered into Table1 the calculated Net Lbs figure would reflect the post Oct 5, 2002 poundage calculation? Please keep in mind that the conversion factors could change many times over.
Date = date of data entry;
Code = produced item;
Cases = number of cases produced;
Net Lbs = (a calculated poundage based upon the Code and Lbs in Table2.
Table2: Date Code LbsCode = produced item;
Date = date of entry of this particular Code/Lbs entry into Table2;
Code = produced item (as in Table1);
Lbs = a conversion factor to calculate the number of Lbs per Case.
Everything works perfectly until the Lbs/Case figure in Table2 is changed to reflect a newer, up to date, poundage for a case of any particular product.Code = produced item (as in Table1);
Ex: On Jan 1, 2000 the Lbs/Case of Widgets was 50. Then, on Oct 5, 2002 the Lbs/Case of Widgets changed to 45.
