Hi All,
I copied this macro from the Ron DeBruin site and it works well. It splits one workbook into multiple work books based on the column that I select and creates an email for each workbook. I don't need to email the files so I tried to comment out those lines. I need help solving the compile error that results. Here is the code:
Sub Split_To_Workbook_and_Email()
'Working in 2013/2016
Dim FileExtStr As String
Dim FileFormatNum As Long
Dim Sourcewb As Workbook
Dim Destwb As Workbook
Dim sh As Worksheet
Dim DateString As String
Dim FolderName As String
Dim myOutlook As Object
Dim myMailItem As Object
Dim mySubject As String
Dim myPath As String
With Application
.ScreenUpdating = False
.EnableEvents = False
.Calculation = xlCalculationManual
''Prompt for Email Subject
'Set otlApp = CreateObject("Outlook.Application")
'mySubject = InputBox("Subject for Email")
'Copy every sheet from the workbook with this macro
Set Sourcewb = ActiveWorkbook
'Create new folder to save the new files in
DateString = Format(Now, "yyyy-mm-dd hh-mm-ss")
FolderName = "C:\Temp\" & Sourcewb.Name & " " & DateString
MkDir FolderName
'Copy every visible sheet to a new workbook
For Each sh In Sourcewb.Worksheets
'If the sheet is visible then copy it to a new workbook
If sh.Visible = -1 Then
sh.Copy
'Set Destwb to the new workbook
Set Destwb = ActiveWorkbook
'Determine the Excel version and file extension/format
With Destwb
If Val(Application.Version) < 12 Then
'You use Excel 97-2003
FileExtStr = ".xls": FileFormatNum = -4143
'You use Excel 2007-2016
If Sourcewb.Name = .Name Then
MsgBox "Your answer is NO in the security dialog"
GoTo GoToNextSheet
FileExtStr = ".xls*": FileFormatNum = 51
'Change all cells in the worksheet to values if you want
If Destwb.Sheets(1).ProtectContents = False Then
With Destwb.Sheets(1).UsedRange
.Cells.Copy
.Cells.PasteSpecial xlPasteValues
.Cells(1).Select
'Save the new workbook, email it, and close it
'Set otlNewMail = otlApp.CreateItem(olMailItem)
With Destwb
.SaveAs FolderName _
& "\" & Destwb.Sheets(1).Name & FileExtStr, _
FileFormat:=FileFormatNum
myPath = ActiveWorkbook.Path & "\" & ActiveWorkbook.Name
With Destwb
.Close False
'With otlNewMail
'.Subject = mySubject
'.Body = " "
'.Attachments.Add myPath
'.Display
'End With
'Set otlNewMail = Nothing
'GoToNextSheet:
Next sh
MsgBox "You can find the files in " & FolderName
With Application
.ScreenUpdating = True
.EnableEvents = True
.Calculation = xlCalculationAutomatic
Thanks in advance for any advice and solutions!
Dim sh As Worksheet
With Application
MkDir FolderName
sh.Copy
With Destwb
GoTo GoToNextSheet
.Cells.Copy
.Cells(1).Select
With Destwb
With Destwb
.Close False
'With otlNewMail
'.Body = " "
'.Display
'End With
'GoToNextSheet:
Next sh
With Application
