Hi
By counting the spaces I assume you mean counting the "apparently" blank cells between each cell that contains letters. And I say "apparently" because some of them aren't really blanks - some have zeros and others seem to have some value that my excel can't read, although it can tell the cell isn't blank.
This poses a problem in finding a proper solution. I was able to find one but only after cleaning the file by getting rid of those "false" blank cells.
If your actual file is much bigger then I don't know what your approach should be here...
Anyway, please see if the file attached helps with your problem.
KR
Hi
KR
