realhiphop
I have a spreadsheet I've created that has the data on one table and the lookups on the other.
The criteria I'm trying to look up is as follows:
1. A2, A7, "A". All of this data is being looked up from the data tab. A2= Column C, A7= Column I, and "A" is going to be looked up from Column H.
The issue is that there are multiple players on each team that can be played at OF (column I from Data), and U. This is going to show duplicates. I'd like the duplicates to show.
The result in Lookups Column B is going to come from Data Column E.
I am then going to lookup Columns E through I on row 6 based on the result in column B.
Thanks in advance
Thanks in advance
