Need Help VBA or Formula
J@rv!s
I need formula or VBA code to pull some records in this scenario there are some teams they are going play matches with each others.
All I need is if I put Team name in Cell I1 below that cell all the records should show or extract from the table there are two columns for the teams the team which I am looking for should be any where in two columns.
I have uploaded an excel file
Thanks in advance.
Formula way,
1] F2, enter formula :
=IF((B2=I$1)+(D2=I$1),MAX(F$1:F1)+1,"")
and, F2 >> Custom Cell Formatting >> in the type box enter: ;;;
all copy down
2] J1, enter formula :
=LOOKUP(9^9,F:F)
and, J1 >> Custom Cell Formatting >> in the type box enter: ;;;
3] I4, formula copy across and down :
=IF(ROWS(A$1:A1)<=$J$1,INDEX(A$2:A$22,MATCH(ROWS(A$1:A1),$F$2:$F$22,0)),"")
Bosco
VBA, if you like
To Sheet1 code module
This will be fired whenever you change the value in I1.
    Dim x
    If Target.Address(0, 0) <> "I1" Then Exit Sub
    With Intersect(Columns("a:e"), UsedRange)
        x = Filter(Evaluate("transpose(if((" & .Columns(2).Address & "=i1)+(" & .Columns(4).Address & _
        "=i1)+(row(" & .Address & ")=1),row(1:" & .Rows.Count & "),char(2)))"), Chr(2), 0)
        If UBound(x) > 0 Then
            x = Application.Index(.Value, Application.Transpose(x), [{1,2,3,4,5}])
            x = Empty
    With Application
        .EnableEvents = False: .ScreenUpdating = False
    With [i3].CurrentRegion
        With .Offset(1)
            .Borders.LineStyle = xlNone: .ClearContents
        If IsArray(x) * (Target.Value <> "") Then
            With .Resize(UBound(x, 1))
                .Value = x
                .FormatConditions.Delete
                With .FormatConditions.Add(Type:=2, Formula1:="=i3=$i$1")
                    .Font.Bold = True
                    .Font.Color = 192
                .Borders.Weight = 2
    With Application
        .EnableEvents = True: .ScreenUpdating = True
