gurinderwalia
I need to your help with a formula im trying to build and its been days I have tried my ways but I haven’t reached anywhere
I have attached a sheet which is sample file…below are the steps I take to update.
Is tehre a way to create a formula which takes count and cover the cells I need to my to mid and bottow.
Sample is given for you to refer
- I filter the data by Month as I have 6 months data.
- I filter it by unit as I have two unit
- I have 8 different columns with 8 metrics.
- 1st select the first data column and sort is desc to asc.
- I count the total day on that column.
- For eg if its 50 then I need the top 30. Mid 40 and bottom 30
- I multiply 50*30% give me m top30 and bottom 30 which is 15 each
- Remaining 20 as my mid40 percent
- I have to do this manually and assign the name on E Column for the first 15 entries as T30 then go on to other 20 and type M40 and remaining as B30.
- Now I have data in thousands and it’s a very tedious task to do this everytime manually.
