Need help related to LET function
razaas
Hi, Below formula is working fine and spills result as desired, I want help to add a headings row in the top row of the spill range, my spill range has 3 columns, I want to have "Value1", "Value2","Value3" as column names. Thanks
=LET(end_of_month_dates1, EOMONTH(--Table3[Date], 0),
end_of_month_dates2, EOMONTH(--Table3[Date], -1),
unique_dates1, UNIQUE(SORT(end_of_month_dates1, , -1)),
unique_dates2, UNIQUE(SORT(end_of_month_dates2, , -1)),
current_month, INDEX(Table3[End of Month], MATCH(unique_dates1, Table3[Date], 0)),
previous_month,INDEX(Table3[End of Month], MATCH(unique_dates2, Table3[Date], 0)),
month_on_month,current_month-previous_month,
IFERROR(CHOOSE({1,2,3}, unique_dates1, current_month,month_on_month),0)
You can add in VSTACK:
VSTACK({"Value1","Value2","Value2"},IFERROR(CHOOSE({1,2,3}, unique_dates1, current_month,month_on_month),0))
Thanks a lot for the reply, my version of Excel does not have VSTACK Function, any other option? Thanks
Add the titles manually and put the LET formula in the cell below?
Thanks for the suggestion, I had already done that but was expecting to find solution to spill thru 1 formula, I will wait for more replies and possibly a solution. Thanks
The following variant should be compatible with Excel 2021:
=LET(
    current_month,  XLOOKUP(unique_dates1, Table3[Date], Table3[End of Month]),
    previous_month, XLOOKUP(unique_dates2, Table3[Date], Table3[End of Month]),
    month_on_month, current_month - previous_month,
    results,  IFERROR(CHOOSE({1,2,3}, unique_dates1, current_month, month_on_month), 0),
    row_nums, SEQUENCE(ROWS(results) + 1, , 0),
    IF(row_nums, INDEX(results, row_nums, {1,2,3}), {"Value1","Value2","Value3"})
=LET(
Thanks a lot, it works.
