Need help on
Here is a UDF that you can employ but you will need to change how your worksheet is arranged; your lookup values in your table range needs to be in the left most column of the data you are searching. Same as using the Vlookup function. Here is the code and I have attached your workbook changed to show the results.
Function VLookupMulti(ByVal strIndex As String, ByVal rng As Range, _
                      Optional ref As Integer = 1, Optional myJoin As String = " ", _
                      Optional myOrd As Boolean = True) As String
' jindon
' http://www.mrexcel.com/forum/showthread.php?t=344561&highlight=muvlookup
' =VLookUpMulti(A1, C1:D100, 2, ",", False)
    Dim a, b(), i As Long, n As Long
    a = rng.Value
    ReDim b(1 To UBound(a, 1), 1 To 2)
        .CompareMode = vbTextCompare
        For i = 1 To UBound(a, 1)
            If a(i, 1) = strIndex Then
                If Not .exists(a(i, ref)) Then
                    .Add a(i, 2), Nothing
                    n = n + 1: b(n, 1) = a(i, 2)
                    b(n, 2) = IIf(IsNumeric(a(i, 2)), a(i, 2), UCase(a(i, 2)))
    VSortM b, 1, n, 2, False
    For i = 1 To n
        VLookupMulti = VLookupMulti & IIf(VLookupMulti = "", "", myJoin) & b(i, 1)
End Function
Sub VSortM(ary, lb, UB, ref, myOrd)
    Dim i As Long, ii As Long, iii As Long, m, temp
    i = UB: ii = lb
    m = ary(Int((lb + UB) / 2), ref)
    Do While ii <= i
        If myOrd Then
            Do While ary(ii, ref) < m: ii = ii + 1: Loop
            Do While ary(i, ref) > m: i = i - 1: Loop
            Do While ary(ii, ref) > m: ii = ii + 1: Loop
            Do While ary(i, ref) < m: i = i - 1: Loop
        If ii <= i Then
            For iii = LBound(ary, 2) To UBound(ary, 2)
                temp = ary(ii, iii): ary(ii, iii) = ary(i, iii): ary(i, iii) = temp
            i = i - 1: ii = ii + 1
    Loop
    If lb < i Then VSortM ary, lb, i, ref, myOrd
    If ii < UB Then VSortM ary, ii, UB, ref, myOrd
  • Sample.xlsx
' jindon
    a = rng.Value
    For i = 1 To n
End Function
    i = UB: ii = lb
    Do While ii <= i
        If myOrd Then
        If ii <= i Then
    Loop
Sir,
Thanks a lot for your valuable time on this. This is what i was looking for but can we change the order of concatenate to reverse?
Now, from lower to high position.
