Need help on vlookup macro with multiple criteria
I have DM and Account list as in Table2 in attached file and SL mapped wrt DM and account data. I wish to lookup the SL from table 2 in SL column of Table 1.
It should use both DM and Account for mapping. I'm new to Excel macro.
Your help would help me a lot.
Attaching the data file.
  • mapping_sample.xlsx
Hi Prashant,
If you are comfortable with formula, try below formula in F4 and copy down:
=INDEX($M$4:$M$10,MATCH(E4&D4,$K$4:$K$10&$L$4:$L$10,0))
Note this is an array formula, so must be entered with Ctrl+Shift+Enter. (See the file)
Hi Prashant,
If you are okay with adding helper columns, add one column in each of the table. The column will have formula to concatenate DM and Account. do the same in Table 2 as well.
After that use vlookup() to fetch the results.
tip: use help column in table 2 on left side of SL column so that vlookup can be used.
Prasad DN
