Hi there
Please help me with a VBA code to get the below things from a machine log file,
Info:-
1. One cycle means Time between Process start and Process end, Refer column C in the workbook.
2. Machine interruptions are captured in column E.
3. Cycle time, i,e; Time difference between process start and process end for each cycle in the column F
Requirement:-
1, If there is any interruption in any cycle, it is not a success run, So success should not come in column G,
2, If there is no any interruptions in a cycle, it is a success run so success should come in the respective row,
Currently, I am using a macro which inserts the formula for some cells,
All calculated values should come in respective rows in column I.
Please help me as soon as possible.
Thanks,
Yathi
Info:-
Requirement:-
Thanks,
Yathi
