Dim iRow As Long
Dim ws As Worksheet
Set ws = Worksheets("sheet1")
'find first empty row in database
iRow = ws.Cells.Find(What:="*", SearchOrder:=xlRows, _
SearchDirection:=xlPrevious, LookIn:=xlValues).Row + 1
'check for a part number
If Trim(Me.TextBox1.Value) = "" Then
Me.TextBox1.SetFocus
MsgBox "Please enter a part number"
Exit Sub
'copy the data to the database
'use protect and unprotect lines,
' with your password
' if worksheet is protected
With ws
' .Unprotect Password:="password"
.Cells(iRow, 1).Value = Me.TextBox1.Value
.Cells(iRow, 2).Value = Me.TextBox2.Value
.Cells(iRow, 3).Value = Me.TextBox3.Value
.Cells(iRow, 4).Value = Me.TextBox4.Value
' .Protect Password:="password"
'clear the data
Dim lastrow As Long
lastrow = Cells(Sheet1.Rows.Count, "b").End(xlUp).Row + 1
Range("a" & lastrow).Value = TextBox1.Value
Range("b" & lastrow).Value = TextBox2.Value
Range("c" & lastrow).Value = TextBox3.Value
Range("d" & lastrow).Value = TextBox4.Value
Range("e" & lastrow).Value = TextBox5.Value
Range("f" & lastrow).Value = TextBox6.Value
Range("g" & lastrow).Value = TextBox7.Value
Range("h" & lastrow).Value = TextBox8.Value
TextBox1.Value = ""
TextBox2.Value = ""
TextBox3.Value = ""
TextBox4.Value = ""
TextBox5.Value = ""
TextBox6.Value = ""
TextBox7.Value = ""
TextBox8.Value = ""
Dim lastrow As Long, chk As Boolean, x As Object
With Sheet1
lastrow = .Cells(.Rows.Count, "b").End(xlUp).Row + 1
For i = 1 To 8
If Not Me.Controls("TextBox" & i).Value <> "" Then
Me.Controls("TextBox" & i).BackColor = vbRed: chk = True
Me.Controls("TextBox" & i).BackColor = vbWhite
If chk Then MsgBox "Pls correct rex boxes", vbCritical: Exit Sub
For i = 1 To 8
Set x = Me.Controls("TextBox" & i)
.Cells(lastrow, i) = x.Value
x.Value = "": x.BackColor = vbWhite
Set x = Nothing
Hi Ashhu,Dear Rupesh,
I am unable to complete the code as i am leaving now, but i have made sure the data to fill when you hit Next button. Gaps are still there, i mean Scope of Improvement are there.
Copy below code in Module, and try. same way you can do for rest. Sorry for imcomplete code, if no reply i will update it for you tomorrow.
Code:Private Sub CommandButton1_Click() Dim iRow As Long Dim ws As Worksheet Set ws = Worksheets("sheet1") 'find first empty row in database iRow = ws.Cells.Find(What:="*", SearchOrder:=xlRows, _ SearchDirection:=xlPrevious, LookIn:=xlValues).Row + 1 'check for a part number If Trim(Me.TextBox1.Value) = "" Then Me.TextBox1.SetFocus MsgBox "Please enter a part number" Exit Sub End If 'copy the data to the database 'use protect and unprotect lines, ' with your password ' if worksheet is protected With ws ' .Unprotect Password:="password" .Cells(iRow, 1).Value = Me.TextBox1.Value .Cells(iRow, 2).Value = Me.TextBox2.Value .Cells(iRow, 3).Value = Me.TextBox3.Value .Cells(iRow, 4).Value = Me.TextBox4.Value ' .Protect Password:="password" End With 'clear the data End Sub
