Need help in Pasting data in a filtered data range
Kiran Kumar
Hi there,
Need one more assistance on copy & pasting data.
For example, I copy data from spreadsheet1 and wanna paste the data in spread sheet. The challenge is i filter some columns in the spreadsheet2 for some validations and then I wanna paste the copied data onto the filtered range.
The problem is, if i paste the data on the filtered range, the data will not get pasted on the visible cells.
can some one look onto this solve for me pls.
Rds,
Kiran Kumar
If you name the range with values that you want to copy "CopyRange", then select the region of cells that you want to copy to, I believe this macro will work for you.
[pre]
Sub Copy_Filtered_Cells()
Dim SourceRange As Range, TargetRange As Range
Dim Cell As Range, i As Integer
If ActiveSheet.FilterMode = True Then
Set SourceRange = Range("CopyRange")
Set TargetRange = Selection.SpecialCells(xlCellTypeVisible)
With Application
.ScreenUpdating = False
For Each Cell In TargetRange
i = i + 1
SourceRange.Cells(i).Copy Cell
.CutCopyMode = False
[/pre]
thats fantastic. it would be great if we have a technique to paste directly without running some macros. It is difficult to set a named range for copied and cells and then select the filted range and then running macros.... oooh! Pls let me know if there is any technique to paste it in a visible cells of a filtered range or else i will go with this macro code only.
thank again for your help on this.
