Need Help in formula to avoid blank cells
Ateeb Ali
Dear Sir
Attached file, I need help in formula where I can avoid blank cells;
the formula currently I am using is;
=+IF(A2<>0,A$1,"")
Its pasted all the way from J2:Q17
It also showing empty space, I need to add some formula to it does not show empty cells, I have mention same in worksheet with highlighted "Required"
  • chandoo.xlsx
Try,
1] In I2, copied down :
=COUNT(A2:H2)
2] In J2, copied across and down :
=IFERROR(INDEX($A$1:$H$1,AGGREGATE(15,6,COLUMN($A$1:$H$1)/($A2:$H2>0),COLUMN(A1))),"")
Bosco
  • AvoidBlankCells.xlsx
Coming soon in Office 365!
= FILTER( heading, datarow )
where 'heading' is the row starting "Needle1" and 'datarow' is a relative reference to a single row of data below it. Because the data is numeric, any blank counts as 0 / FALSE and any number as TRUE. The relevant headings are copied into a contiguous row of cells as a spill formula.
Dear Sir
I just attached sample workbook, your formula worked perfect but when I changed it to actual placement, its not working, see attached file
Using this formula but not working;
=IFERROR(INDEX($G$3:$N$3,AGGREGATE(15,6,COLUMN($G$2:$N$2)/($A2:$H2>0),COLUMN(G2))),"")
  • AvoidBlankCells1.xlsx
Helping
Correct formula
=SEERRO(ÍNDICE($G$2:$N$2;AGREGAR(15;6;COL($G$2:$N$2)-6/($G3:$N3>0);COL(A1)));"")
and copies to other cells
Decio
Apologies do not translate the formula the language is Portugues Brasil
Follows the attachment
Decio
  • AvoidBlankCells1 Decio.xlsx
Dear Sir
Try this in P3, copied across and down :
=IFERROR(INDEX($G$2:$N$2,AGGREGATE(15,6,COLUMN($G$2:$N$2)-COLUMN($G$2)+1/($G3:$N3>0),COLUMN(A1))),"")
Bosco
  • AvoidBlankCells1A.xlsx
